It is currently Thu Aug 14, 2025 8:30 pm
 Post subject: Fretting question
PostPosted: Thu Sep 10, 2015 9:46 am
Last Name: Tays
Country: canada
Newbie question. I had to pull 4 frets out of my neck and the replacement wire I have doesn't want to fasten in the middle. I am using caul in a drill press to press the wire in. Wondering if crazy glue in the slots will hold the wire long term? I know about the tang crimper i just don't have one. Thanks for any help in advance
 Post subject: Re: Fretting question
PostPosted: Thu Sep 10, 2015 2:02 pm
First name: Tom
Last Name: West
State: Nova Scotia
Dave: I use CA glue on all the frets I install. I only build and don't do repair work. I hold the fret tight with a caul and run CA the length of the fret. Acetone and a single edge safety razor blade work for glue cleanup.
Tom
PostPosted: Thu Sep 10, 2015 4:51 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
Hi Dave, I believe the general consensus is that frets should be glued in. As far as crimpers go, Somogyi has a block of wood with a slot filed in it. He puts the fret in there, tang side up, and whacks it with the spine of a cleaver.
If it's good enough for Ervin... :-)
These users thanked the author JSDenvir for the post: Ken Jones (Fri Sep 11, 2015 1:58 am)
PostPosted: Fri Sep 11, 2015 7:33 am
Yes we do use a tiny bit of CA on the ends of the fret wire. However since you mention its popping up in the center it may help if you re-shape the radius a little before installing to reduce spring back. I know makers also use PVA and even epoxy if the slots are a little too wide.
Ken Cierp
PostPosted: Fri Sep 11, 2015 10:57 am
Last Name: Tays
Country: canada
Thanks for the help.
Users browsing this forum: Bing [Bot], DennisK and 31 guests
